Cool design; if it takes hold, more car manufacturers I think would incorporate turbocharging into their cars because this design solves most problems associated with turbos. It has a twin scroll exhaust housing that divides the cylinders into 2 ports in the exhaust manifold/turbine housing. 1 scroll is smaller, the other bigger which in and of itself creates a sort of variable exhaust housing size for quick response and bigger top end power. Plus it has better exhaust scavenging. It also has a valve that closes at low rpms and makes the exhaust housing smaller which speeds up the exhaust and spools the turbo quicker; the valve opens at higher rpms/backpressure for good top end power.
