1951FORD
Thread starter
Originally Posted By: roadrunner1
I still have two flatheads, with one getting used regularly, for motor oil you really can't beat an HDEO for one of these Fords. I have been running 15w-40 in them for at least 25 years, and before that it was straight 30 wt HDEO. I would be hesitant to run anything thinner that a 40 wt. due to such low oil pressure on these when hot. Mine run a power take off at idle and warm oil pressure idling on any flathead will always require a second look.
I will recommend MMO as a gas additive, along with stabil. It seems to keep the combustion chambers/spark plugs cleaner, but as mentioned mine idle 98% of run time.
Thanks roadrunner1, we still have my father's '48 Ford F-6 boom truck with PTO that we used to lift cars with in the junkyard. He bought a Ford flathead 8BA rebuild crate engine back in the '60's for it. Running ever since. Not as much use now, the junkyard is gone. I use Stabil for mine, MMO I still need to know more science, but I respect the advice, my Dad swore by MMO,
