06 GMC Sierra
Driver side window stopped working. Friend and I had door panel off. (He is capable, I'm helper, tool holder) Changed the window motor/regulator to a new unit. The only thing that doesn't work on the driver door switch panel is the driver side window. Everything else works. So after putting on the new motor, same thing, driver side window didn't work. So I leave off door panel and figure I will try junk yard for a new window control and the window starts working on the ride home. What the ..... Hasn't worked for 2 weeks.
We looked for a fuse but couldn't find it, didn't specify in owners manual.
Any thoughts? Must be the unit that contains the windows, locks.
