Originally Posted By: Gokhan
According to this SAE paper, thinner oils were a lose - lose choice in these two cases. The car that was already fuel-efficient (Car 1) saw decreased fuel economy with thinner oils. The not-so-fuel-efficient car (Car 2) saw increase in fuel economy but I am guessing that it's a high-performance car, which means, thinner oils will not work (they will result in excessive wear) when you get the performance/load from it that it's designed for, rather than the standard dyno fuel-economy test that mimics normal driving.
Did you read the paper??? - if you did I would love for you to provide some clarification to your analysis.
If you didn't read the paper, but are simply using the abstract to reinforce your preconceived notion about the affect of engine oil on fuel economy then I'm calling you out.
The actual conclusion of the paper was more like this:
Quote:
The variable “oil” revealed to have a highly statistical
significant effect on fuel consumption and CO2 emissions, as
well as the interaction between the variables “oil” and
“vehicle”. This latter result is the statistical confirmation that
the two vehicles provide a different ranking of the test oils.
In both cases there was fuel economy improvement - how much was impacted by vehicle design. The authors also note in the conclusion that there were other factors in the behavior of vehicle 1 that could explain why the 2.0 HTHS oil may have responded in the slight decrease of fuel economy vs the 2.3 HTHS oil. That's not a lose-lose situation that's a statistically significant effect that warrants further investigation. Which, since this paper was published in 2013, I'm sure has already been started.
