My buick runs good when starts up, if the temp is cold outside like 30 degrees, when you shut the car off for 10 mins or so and start it up it will run real rough bad, after about 20 seconds or so it will run normal, only when its cold outside it will do this, in warm weather its fine, not check engine light, again only when cold, and first start in morning when cold starts right up!
