Purchased the car in August. It's a 2014 Mazda 5 van with 2.5L engine and 5-speed A/T. Dealer claims to have changed oil at 30,600 miles in June with 0w-20 synthetic (don't know brand). I figured I'd change it at 34K just in case besides it's close to OM interval in terms of time. Everything looks good per Titan Labs. Poured in M1 0w-20 EP and installed Wix filter.
I should have analyzed the ATF (Mazda Type M5) instead but didn't get a sample during drain and fill. Darn.
Any guesses as to what fluid this is? I wonder if anyone can tell by additives. The dealer is Carmax so I would rule out OEM although you never know...
Code:
Miles on unit 33,800
Miles on oil 3,200
Months on oil 5
Sample date 11/13/2015
Oil used 0w-20 synthetic?
Filter used Carquest red
Aluminum 1
Chromium 0
Iron 5
Copper 2
Lead 0
Tin 0
Nickel 0
Silver 0
Molybdenum 73
Manganese 0
Titanium 0
Calcium 1909
Magnesium 14
Phosphorus 652
Zinc 767
Barium 0
Boron 145
Sodium 6
Silicon 5
Potassium 3
PROPERTIES
SUS Viscosity @ 210°F 51.40
cSt Viscosity @ 100°C 7.70
Coolant % Negative
Water % Negative
Oxidation 12
Nitration 8
Sulfation 19
Code:
Miles on oil 3,200
Months on oil 5
Aluminum 1
Chromium 0
Iron 5
Copper 2
Lead 0
Tin 0
Nickel 0
Silver 0
Molybdenum 73
Manganese 0
Titanium 0
Calcium 1909
Magnesium 14
Phosphorus 652
Zinc 767
Barium 0
Boron 145
Sodium 6
Silicon 5
Potassium 3
PROPERTIES
Coolant % Negative
Water % Negative
Oxidation 12
Nitration 8
Sulfation 19
