Hi all
I have a 2003 CL55 AMG Kompressor. It has had 3 liters of oil top ups in the last 6800 miles. Most of the time the car is driven quite hard, but there is motorway trips in there etc.
I have fixed all common sources of leaking oil on this engine (Rocker cover gaskets/breathers etc).
There is little evidence that the car has an engine fault, there is no blowby from the oil filler cap or dipstick cap when cold, the car blows no blue smoke at all when starting or driving hard.
The only time I see a small puff of blue smoke, is if the car is revved after idling for a long long time (more than 30 minutes).
The plugs where changed and looked sooty but not oily.
I sent off the oil for analysis (6800 miles on the oil, Shell Helix Ultra 5W40) and it came back with this results:
My thoughts are that the iron is a bit high. Millers have said that its normal though? Any thoughts.
