- Joined
- Nov 29, 2009
- Messages
- 7,268
I worked at a place that repaired pumps and occasionally I'd help out in the shop. Well the mechanic was kind of a do it his way or not at all kind of guy. So he would have me take apart a pump with 9/16" open end box end wrench. They always complained how I was too slow. Meanwhile he uses an impact wrench or air ratchet to take the pumps apart. If they won't let me use air tools at least let me use a regular ratchet. I've noticed this quite frequently and it's not just me. I guess the slowest method is also the least likely to mess something up. Maybe that's their thinking? I always use a ratchet and only use a wrench if I need to hold a bolt still while I loosen. For some reason this guy never used a ratchet.
