Originally Posted By: HerrStig
Originally Posted By: Astro14
Supton - That's a specious conclusion.
A failed solder joint brings down the airplane?
I would have been dead thirty years ago if a systems anomaly was a valid reason for airplane crashes.
Compensating for the system failure is what pilots do. When they fail in that task, airplanes crash.
When you've got "fly by wire" it's a risk. Several 737s went in because of bad hydraulic rudder controllers, though, so it isn't just electronics.
If pure mechanical systems were perfect, no DC-3 would have ever crashed, right?
The 737 problem was also partly a cost-reduction problem: there was no longer a split/redundant rudder. It was pointed out at the time that the same failure could happen in one of the rudder controllers on a 727, but it wouldn't have brought down the plane because the rudder was split and the other half could have compensated for the failed half. The 737 had a single non-redundant system.
