There was a little bit of wheel shake during moderate braking, I went check out the recently newly installed brake pads / rotors, when removing one of the lug nuts, the nut came loose then tightened up. Don't know why, didnt appear to be cross threaded. FYI, this is the 1st time I worked on the car as we just purchased this a couple of months ago for my daughter. Anyway, this was the only nut that was stuck. I proceeds to remove it with a cross tire iron and the nut made it to the tip of the bolt and then the bolt snapped with the nut stuck on it. I went to the Toyota dealer 5 min away from me and got a new lug bolt & lug nut for under $7. Had to remove the dust shield first, but hammered the old bolt out and hammered the new one in. Cleaned and lubed the pads/calipers/rotors and now everything is good. I thought at first I had to replace the entire hub because of the broken bolt, thank goodness it was a cheap and easy fix
