On my '89 Prelude the outside fan behind the radiator (on left side if standing in front of car) always runs if the AC is turned on and the ignitions switch is turned on (Even if the engine is not running). I can turn the AC switch "off" inside the car and with the ignition still on and the fan WILL turn off.
In other words, if the ignition switch is turned on and the AC is turned on the outside fan will run. This is regardless of the engine being cold or hot or running or not running. If I turn the AC switch off, then the fan will quit running.
This isn't normal is it?
