This is a RUUD Heat Pump. It was manufactured 04/99 (probably on 04/01/99 is my guess
It is the downstairs unit. The original upstairs unit was nearly identical except for the graphic above the fan motor and the absence of the red reset button near the line set exit on the condenser assembly. The upstairs unit has been replaced.
That button is the beginning of the question: It has to be pushed frequently. Sometimes it will go months some times you might have to push it a few times day. Our AC guy says basically "they all do that".
Up until today nothing has ever happened when the button was pushed except that the fan started running and the unit started working. Today I pushed it and the unit buzzed but the fan did not run. I pulled the lockout and checked that the motor seems to turn freely without noise or indications of failed bearings. Did a little google and found the start capacitor is a common problem.
I could not see the identification on the capacitor, so I removed it to read the label (370V, 35.0/3.0) round. After I put it back in the unit ran for a while. When it runs it sounds completely normal.
Questions:
Thank you in advance for any thoughts.
Questions:
- Does this sound like a bad start cap?
- Would a bad start cap trip the reset button?
- Any other ideas to fix the frequent reset?
