Originally Posted By: Robenstein
Indian only sells 20w40 and 15w60...the 20w40 is also used in the Polaris Victory line and was always the recommended oil for the chief line.
The 2015 Scout manual lists only 15w60 in the oil recommendation, same as it does in the 2016.
http://polaris.hs.llnwd.net/o40/archive/ind/2015/manuals/9925953r02_IND_Scout_OM_Lo-Res.pdf
True... I failed to double check the date... my Scout manual is 2003 which list only 20w50 SG
