The making of the shif knob
Bolivia
Nothing seems to be available for the Auto transmission in my Mini Pickup, so I cut a branch off my dead walnut tree and went over to a friend's house this morning to borrow his lathe.
A few hours later, I had the finished shift knob/handle
Beautiful!
This post is one of the reasons I can't stay away from Bob Is The Oil Guy!
Thank you Mr. Widman!
I had a nice Hurst T shift handle in my 1965 Mustang. It was metal. Burn your hand in the summer.
But I do like the wooden one. Very classy.
Thanks for the compliments.
Quote:
Did you use a threaded insert to attach it?
I drilled out the center, then widened the end of the hole with a dremmel to fit a nut.
The thing that looks like the aircraft hangar is my garage. It is about 24' x 30' with the side work bench/tool area sticking out 4' x 10'. That area has 3 boards 3" x 8" for a work bench with their ends embedded into the brick walls. Sturdy, with no legs under it.
