The engine load and peak cylinder pressure in late model trucks allow for 10W30 instead of 15W40.
That does not mean the GRADE is backward compatible with older engines.
I could get away with 0W16 in my Duramax by backing off the throttle during shifts and keeping the rpm a little higher under load.
The blanket statement of 15W40 being stuck in the past gets old after the millionth time it is posted.
My owners manual states 15W40 and 5W40 as the only two options for the Duramax.
My old pre-def LBZ 06 listed 10W30 as an option, since deleted in the new models.
