Originally Posted By: gallydif
Originally Posted By: Lapham3
If some polishing compound doesn't do it, I'd try some 1500 grade wet/dry paper-good luck
I tried 1500 wet the other day on my car for overspray and ended up scratching the paint. I'm going to just take it to my guy at the body shop to fix what I've already done before I F--k it up some more.
Went to the body shop. He hit it lightly with 3000 grit sandpaper wet. Then used rubbing compound- 3M 06085 to be exact. I'm amazed. Came out brand new. And now I know how to do it myself since I watched him do it.
And to get overspray off glass do NOT use sandpaper. Go over it lightly with a razor blade.
