Originally Posted By: ram_man
Our pt cruiser uses about. A quart every 1500 miles I've tried various oils ect nothing has fixed it. It's basically just the way the pcv system is designed. Instead of changing it should I just add it when it needs it and change the filter every. 5,000 or so? What do you think.
Is that the 2.4L with the 4 quart sump? If so, you're replacing the entire sump in 6000 miles. I'd go at least 10k before changing, and get a UOA at that point to see how things are - you might not need to change for quite awhile. You may consider a higher mileage filter, or just keep changing it at 5k, whatever makes more sense for you.
