I have mixed feelings about timing belts.
I think all TB-equipped engines should be non-interference. A fellow at a local import-specialist parts recycler told me that most of the engines they sell are Honda engines, to replace those destroyed by broken TBs.
However, timing chains (or their plastic guides) do fail, and they're typically not as easy to change as TBs.
In general I'd say TCs are best for all OHV (cam-in-block) engines.
For a simple (in-line) SOHC engine, a TC is a good solution.
For a complex engine (V-type, DOHC), the routing is usually complex, and a TB is better than a TC.
For an in-line DOHC or a V-type SOHC, it's a bit of a coin toss.
Consider the complex European TC-equipped engines you'll see in various threads here. What were they thinking?
Or Ford's 4.0 OHC ... a chain-driven jackshaft replaces the old cam-in-block, and drives separate chains to the heads. But one chain is driven off the back of the jackshaft, so the engine has to come out to work on the chain. C'mon guys!
A belt that has to be replaced at regular intervals would force the manufacturer to design in accessibility.
Trav, no doubt you've seen some beauties!
FWIW, my fleet (including Jr's car) includes an ancient SOHC V6 with a belt I could almost change in my sleep, a slightly less ancient DOHC inline-4 with a belt that's pretty easy to change, and a later DOHC in-line 4 with a chain.
