JHZR2
Staff member
We upgraded deep freezers at the end of the summer. We had a very small chest type which served us well, but we wanted more volume to keep our berry crops and other food we prepare and keep.
I picked a Frigidaire, ~17cu ft (IIRC), upright model. I got the most efficient one that I could which had no frills - i.e. manual temp control, is a manual defrost design, etc.
The compressor runs a lot, but the unit is very well insulated, and I think the undersized, long-running compressor is probably part of why its efficiency is higher. It has never been particularly noisy, ad in the videos below, take the compressor noise with a grain of salt, the compressor motor type sound is no louder or different than it ever has. It sounds quite loud because of the acoustics in the basement, coupled with the phone microphone I guess. It is not that loud in real life.
But its the other sounds. One is a flowing noise (I get it that refrigerant can flow like a liquid in the coils and can make sound as it is undergoing phase change in flow), and the other is more of a squeaking noise, The sounds are definitely coming from the upper areas in the freezer, I listened closely all around and behind, and can tell that they are coming from the upper coils.
The compressor is warm/hot(ish) to the touch, as is the high pressure line. But nothing extreme, my hand could be on it all day long without worries.
The system does shut off sometimes.
The system is level in both axis.
So, here are two videos to get the sound, FWIW...
In this one it sounds like when a big bubble rises in a water cooler. That is actually more of a squeak sound in real life. The other primary noise you hear in this one is the flow noise that Im hearing. It like the compressor noise, is much amplified for whatever reason...
This one has much more of the compressor noise in it, which isn't actually that loud in real life. The other sounds are pretty well captured...
Any ideas?? Should I be concerned? Its a bit long for it to be a leak or infant mortality. The ambient temperature in the space is about what it always is. There is no new thermal load inside or outside the unit.
