Originally Posted By: Toaster_Jer
MMO isn't such a mystery :70% Light Aromatic Oil (Pale Oil)
- It is a Naphthenic Oil, so while it oxidizes faster than a Paraffinic oil, it does clean and dissolve sludge and carbon well and cleans up after itself from any oxidation. serves as base oil as well. [Naphthenic oils have more solvency and are more polar (they are attracted to metal more), but oxidize faster.
29% Mineral Spirits
- Cleans Varnish very well. General cleaner. Also acts as an antioxidant.
38 parts per million (ppm) Boron
- AW/EP agent, friction reducer, antioxidant
900 ppm Phosporous
- AW/EP agent
1/2% 1, 2 ortho-Dichlorobenzene
- EP agent as it interacts with Iron to form an Iron chloride barrier under any ZDDP or other AW additives. Also very good cleaner/solvent, and friction reducer
1/4% 1, 4 para-Dichlorobenzene
Oil of wintergreen - for the scent
- Not just for the cent, is also a cleaner. may aid lubricity.
Red Dye - for the color
- well this one just colors the stuff
It just works!
Which I assume you pulled from this thread:
http://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2404898
in which Molakule also states:
Originally Posted By: Molakule
As far as claimed benefits or effectiveness, you have to take their word for it or look at public testimonials, or use it yourself, and then decide the costs verses any perceived benefits.
As I have questioned many times, in the context of motor oil additives, what chemical compound do you think we formulators have purposely left out of fully formulated motor oils, to require you to buy OTC or third party additives? ???
Which is pretty much my take on it. It is a high volatility low VI base oil with some mineral spirits and a touch of AW additives tossed in. It is completely obsolete.
