If you smelled gasoline when you pulled your 1989 Honda Prelude with 250,000 miles in your garage after you have shut the engine off, where would you look for the leak? Or where would you start first in trying to find the leak? Are there "likely" locations?
It will still smell like gas in the morning after it sits overnight...
