No, there is more to it than that. Straight drilled are the least expensive rotor and usually not worth resurfacing anyway, these are basically a for looks only rotor.
Properly done they can improve braking performance but they are not cheap and neither are the pads that work properly with them. The radius chamfer is usually down to the rotors min thickness.
Simply using a larger rotor and caliper bracket retrofit from another model with provide much greater performance gains, eg 2002 12" Impala front rotors on a 11" rotor W body with 2002 Camaro calipers makes a lot bigger difference than drilled/slotted 11" rotors.
