It can be easy, and it can be quite maddening.
The rear line on my old s10 failed a few years ago, thankfully I could flare the original line anywhere along the frame with plenty of mess up room. Making the curly line off the master was time consuming, but it came out identical to e original.
On the other hand, the neighbors civic broke a line where it bends up to go over the gas tank. There was JUST enough room to get the flaring tool in there, and no extra line if the flare was bad. That one was a nightmare.
I used the harbor freight double flaring tool. It worked, but with practice I could get about 3 good flares for every 4 made. A hearty, but very even, taper filed on the outside of the line is what took it from 1 out of 2 to 3 out of 4.
