Originally Posted By: DoubleWasp
The FC-W standards are nothing incredible. FC-W certainly does not outline anything beyond the capabilities of a good HDEO. HDEO oils are designed for temps and corrosion resistance beyond what a gas outboard will likely ever see.
Incorrect, CJ-4 requirement is just a copper corrosion test ASTM D6594. For FC-W/FC-W CC approval you have to pass an NMMA specific test that only Intertek and SWRI perform that deals with saltwater corrosion.
