My front left turn signal blinker does not work consistently.
When I activate the left turn signal handle I can see that the flashing light is 2x faster than normal.
I can see that the rear exterior left blinker flashing fast but the front left does not flash at all.
From time to time the left blinker dash light will flash normal and the exterior front left blinker light will also flash at a normal speed.
The front left blinker socket was previously corroded with a white powdery substance.
I cleaned it up the other day and the blinker was working right.
Should I replace the socket or is there something else that might be causing the inconsistent flash?
Tried a new bulb and that didn't work
