Here's a curly one for you.
In my BMW 1M coupe, it uses a GS6-45BZ trans manufactured by ZF.
Redline recommend their D6 ATF in this trans.
http://www.redlineoil.com/product.aspx?pid=115&pcid=7
Discussions surrounding this vs the stock fluid on BMW forums tend to revolve around cold shifting smoothness and fluid viscosity. BMW owners also tend to be utterly petrified about departing from oils that come in BMW bottles. I simply want to use the best I can buy for this gearbox and don't care who makes it. I am also prepared to wait for the box to warm up before driving spiritedly and I l live in a climate which does not fall below 0*C.
What concerns me about using ATF in a manual trans is it's anti-wear add pack. I don't want 'smooth shifting and good synchronizer performance' while sacrificing wear of gear sliding surfaces and shaft bearings. Clearly I need a mixture of these characteristics, I want the box to last, and was leaning towards using Redline MTL until I used their vehicle configurator tool and read some forums where either stock BMW or Redline ATF is the majority.
Anyone want to weigh in on this? I'd love some opinions!
