Originally Posted By: Robenstein
That is erroneous, indeed some manufacturers are trending to THICKER oils. Indian is a perfect example with their 10w60 recommendation for their new scouts. But as Mark Twain once said "Never let the facts get in the way of a good story"
Negative Rob... go back to blowing on your soup at Applebees...
Quote 2015 Indian Owners Manual...
Engine Oil Recommendation
We recommend the use of INDIAN MOTORYCLE Premium Synthetic Blend
20W-40 Engine Oil for your motorcycle. This oil is formulated with
synthetic-based oil and premium engine additive which have physical
properties that meet API SM and ILSAC GF-4 specifications. Do not
blend oil additives with engine oil. If oil must be added in an
emergency and the recommended oil is not available, choose only a
high-quality 20W-40 motorcycle oil. Change back to the recommended oil
at the first opportunity
