The outside handle/latch does not work anymore. The door mechanism works fine from the inside. I see a cable with a ball on it attached to the outside latch itself, at a fork connection of sorts. The cable does not pull tight to the fork, so when I pull on the handle I only catch air.
Would a new cable resolve that?
Thanks.
Thanks.
