- Joined
- Apr 13, 2013
- Messages
- 3,221
I had the VC gasket & valves adjusted at the Honda dealer about 2 yrs back. For the past few months, I've noticed some dried oil along the front of the VC. Honda gaskets are good quality so I don't think it's leaking already. I've read the torque of the VC bolts should be re-checked some time after gasket replacement. Is it common for the bolts to loosen up over time? I don't have a torque wrench that measures 86 in-lbs so I'm just going to use my 1/4" ratchet to check the bolts.
