Used this product for the first time today. CRC seems to make reputable products + it was $2 off AND CRC was offering a MIR of $5. That puts it around $5/can + tax.
Instructions are to insert the thin wand into the intake downstream of the MAS, as close to the throttle body as possible, on a HOT engine. Start the engine, raise throttle to ~ 2000rpm and spray in 30sec bursts. Fortunately, the can will spray upside down.
I noticed several large clouds of blue/purple smoke afterwards when the 30sec was up. Before I used it all, I also thoroughly sprayed the IAC valve.
Rev the engine a few times, turn it off and let hot soak about an hour. Then drive at freeway speeds around 10min. Haven't done the later yet: Waiting for traffic to disperse.
The contents have a very strong smell of PEA, which is a good thing. I'll pull some plugs in a few days and compare before/after.
