Dave at Redline is a nice guy, but sorry, he is wrong. Your 5w20 experiment sheared. I wouldn't have thought the lowly NT700 VTwin would have been hard on oil. The AmSoil appears to have done well, but you are just as likely to have other brands and weights hold up also. Same as Pablo doesn't want you talked out of using it, don't be talked into using it unless you want to for some valid reason. There are other 10w30's that might hang in there and a few 10w40's I know of, BUT, I have no idea what's available in Greece. Do not overlook a stout diesel 15w40 to meet your needs. If Honda says a 10w30 is OK, I'd rather see a 40 weight shear to a 30 that should be OK, vs. a 30 weight shearing out of grade to a 20 that really isn't protecting well. At least you are managing by fact with UOA, that's the only way to really know.
