Changed the external spin-on filter after taking the sample. First run on Amsoil ATF after running the Allison/Castrol fluid in previous fill.
Make/Model: Allison 1000
Vehicle: 2004 Chevy 2500HD
Code:
OIL Amsoil ATF Allison Allison Allison ATF
MILES IN USE 50,547 55,999 45,909 22,681
MILES 183,861 133,314 123,224 99,996
SAMPLE TAKEN 10/7/15 12/8/12 6/13/12 7/19/11
ALUMINUM 11 13 11 9
CHROMIUM 0 0 0 0
IRON 36 34 28 23
COPPER 23 25 23 19
LEAD 26 42 37 34
TIN 0 0 0 2
MOLYBDENUM 0 0 0 0
NICKEL 0 1 1 0
MANGANESE 1 1 1 1
SILVER 0 1 0 0
TITANIUM 0 0 0 0
POTASSIUM 4 2 1 0
BORON 164 133 116 123
SILICON 7 5 4 3
SODIUM 6 6 4 5
CALCIUM 139 72 65 57
MAGNESIUM 1 2 1 1
PHOSPHORUS 412 349 310 298
ZINC 10 11 9 9
BARIUM 1 1 1 1
SUS @ 210 52.7 45.5 46.0 45.1
cSt @ 100 8.08 5.87 6.03 5.77
FLASHPOINT 405 410 375 390
WATER % 0.0 0.0 0.0 0.0
INSOLUBLES % 0.0 0.0 0.0 0.0
TAN 2.6 1.7 2.1
Blackstone Comments:
Thanks for the note about changing the spin-on filter. No insolubles are present in our tests, so the old filter certainly got the job done. Wear metals look great here and lead dropped quite a bit compared to last time. That's nice to see seems how lead was the only metal on the high end back in 2012. The viscosity did measure a bit thick for Amsoil ATF, but we really don't think that's a problem. It certainly didn't cause any excess metal that we can see. There's no moisture or antifreeze either. Put another 10K miles on this oil and filter and just check back.
Code:
ALUMINUM 11 13 11 9
CHROMIUM 0 0 0 0
IRON 36 34 28 23
COPPER 23 25 23 19
LEAD 26 42 37 34
TIN 0 0 0 2
MOLYBDENUM 0 0 0 0
NICKEL 0 1 1 0
MANGANESE 1 1 1 1
SILVER 0 1 0 0
TITANIUM 0 0 0 0
POTASSIUM 4 2 1 0
SILICON 7 5 4 3
SODIUM 6 6 4 5
MAGNESIUM 1 2 1 1
ZINC 10 11 9 9
BARIUM 1 1 1 1
TAN 2.6 1.7 2.1
