Here's my concern I have a 2005 f150 5.4 that I tow my 5000 lb boat with
I usually pull it about an hour one way
I've noticed that my oil pressure will be slightly lower(5-7psi at idle) after about 45 to an hour of towing at the same oil temp
I usually am at 38 psi at idle at 180 degrees
I have a decent size oil cooler
I also have installed a real oil gauge
After about ten minutes at idle oil pressure slowly returns
Ive done quite a bit of reading to try to understand this and I would like some opinions
I am considering running a full
Currently im running 5w20 Mc with Mc filter
Should I go synthetic
Should I go 5w30
Is any of this even related to my problem
There is 78xxx miles on my motor
New tensioners phasers and solenoids
Should I go 5w30
