Originally Posted By: gap599
Is the drain plug on the front or back of the oil pan? In my opinion, the additional amount of oil that would stay in the motor from the slight angle of the ramps is negligible. Even on perfectly level ground not all the oil drains out.
+1
On my car, the oil plug faces the back, so if anything, it's easier for oil to drain from the back of the pan. Either way, as long as you can get the car on ramps, you will be fine changing the oil. I've been using ramps for 5+ years, the same pair actually, and it does great. Have used them to change oil in multiple vehicles. The only car I didn't use them for was a lowered car that only the floor jack could get under (yes it was that low). Use ramps and sleep sound!
