It's the second time that the saginaw power steering pump shaft seal is leaking and I'm debating whether to swap in a junkyard unit or re-sleeve the pump shaft on my truck. Two years ago when I had the pump apart the seal area around the shaft looked polished shiny (no deep grooves or abnormal shaft wear) and left it as is. I'm hoping with the speedi-sleeve it will provide a rough surface to help seal the shaft and stop leaking.
