Originally Posted By: Nate1979
Originally Posted By: SilverC6
Bypasses open every day, especially in the winter, with all oil grades.
They also open under heavy acceleration.
99.9999% ultra filtering efficiency is not required in any automotive engine but is, instead, marketing oneupsmanship for aftermarket filter manufacturers.
Do you have data to support this?
Per Gary Allen on-board testing with a delta-p gauge across the oil filter, it was even pretty hard to get the filter to go into bypass on cold days unless your really revved up the engine just after a cold start-up. So unless some crazy driver is smashing the throttle after a 20 deg F start-up, it's pretty rare for the filter bypass valve to open, unless of course the filter is very clogged up with crud.
