Yeah, Camrys are noted for having rear struts, as well as I think the GM W-body cars (Impala, Grand Prix, etc). They were, to my recollection, MacPherson type designs, with a strut tower vertically with two lower bolts on the knuckle. That provides the damping, load carrying ability, and also camber control. More links are obviously needed for control on other axes.
You also have coil-over-shock designs, where the spring and damper are combined into one unit, even though they provide nothing other than damping and load carrying ability. The Honda CR-V is an example of that. Our current Ridgeline actually is, too. The spring and damper are one assembly, but there are separate links for positional control including camber, toe, etc.
