I've had the same 1996 Lawn boy since new, still runs fine, starts 80% on first pull if it is primed enough )
Winterized, sprayed deck top and bottom with Rust Check, added stabilizer in gas, fresh 10W30 Valvoline Maxlife and new gas cap. The gas cap is the first replacement part needed in 19 years (Not counting plugs, air filters)
It's been a good mower, but I'm thinking it might be replaced in 3 years with something that is more fuel efficient. Appreciate your thoughts.
