I need to replace the temperature sensors on my Ranger. There are two identical looking sensors right next to each other on the thermostat housing. According to the Ford parts diagram, the sensors are two different part numbers. Rockauto also lists both part numbers for my truck. But the old sensors I took out have the exact same part number on them. The part number on the sensors I have is 3l84-12a648 ba. The Ford parts diagram says one part number is a "sensor" and the other is a "sender." The sensor part number is 3L8Z12A648BA and the sender part number is 3F1T-10884-AA. I just ordered one of each from Rockauto, but I'm wondering if that was a mistake since both of the sensors I have are identical. Which ones should I order?
