My Cruze had a miss right around 3000 RPM that had been there for a few months, but only under 10 PSI boost or more. I originally attributed it to its aftermarket tune not having enough flexibility to adapt to the constantly changing weather and gasoline at this time of year. It was also coming up on a spark plug change interval. Mileage is 120,000 miles. So it's had a good long run.
Last night the car started shaking at idle and disabled traction and stability control. A scan showed a code P0304 (cylinder 4 misfire) as pending, but no CEL was lit yet. I limped the car home, popped the hood, and heard a faint sound of electrical arcing. This is what I found:
How to read the coil pack: Cylinder 1 is the left, cylinder 4 is on the right:
I did spill some oil onto that cylinder 4 coil a long time ago during an oil change, and that spark plug subsequently loosened itself up over the course of a few thousand miles. Not the factory's fault, I was in there messing with the plugs early in the car's life. So that coil #4 has seen some things it shouldn't see.
With the cylinder 4 boot removed:
Yep, that's a weak area in the plastic of the boot. It got poked and the plastic crumbled into dust.
Comparison to cylinder 3 coil:
So there's the culprit. $150 later for 4 new plugs (since it was due) and a new coil, no misfire.
