Old sample that was finally tested. This included pulling our cargo trailer from Savannah, GA to Alaska with a couple of tourist stops through the southwest. She got warm, 232F, EGT stayed around 1350F, on I-5's long grades. No slowing down! Tare weight was 11,630 lbs. I will stay with 5w-40 from here on out.
Code:
MI/HR on Oil 10,746 21,466 13,893
MI/HR on Unit 127,455 106,671 85,205
Sample Date 08/10/14 01/13/14 03/05/12
Oil Rotella T5 Rotella T6 5w-40 Rotella T6 5w-40
10w-30
Make Up Oil Added 0 qts .5 qts (Filter) 0 qts
ALUMINUM 4 6 6
CHROMIUM
IRON 49 24 34
COPPER 3 4 14
LEAD 2 1 0
TIN 2 2 3
MOLYBDENUM 3 67 62
NICKEL
MANGANESE Not Tested Not Tested 1
SILVER
TITANIUM
POTASSIUM
BORON 15 23 38
SILICON 11 6 8
SODIUM 5 10 4
CALCIUM 2517 860 970
MAGNESIUM 50 1171 1258
PHOSPHORUS 1091 1070 1098
ZINC 1254 1312 1309
BARIUM
SUS Viscosity @ 210°F Not Tested Not Tested 77.3
cSt Viscosity @ 100°C 12.7 15.0 14.84
Flashpoint in °F Not Tested Not Tested 420
Fuel %
Antifreeze % No No 0.0
Water %
Insolubles % 0.5 0.3 0.1
TBN 6.1 7.2 8.3
Code:
10w-30
ALUMINUM 4 6 6
CHROMIUM
IRON 49 24 34
COPPER 3 4 14
LEAD 2 1 0
TIN 2 2 3
MOLYBDENUM 3 67 62
NICKEL
SILVER
TITANIUM
POTASSIUM
BORON 15 23 38
SILICON 11 6 8
SODIUM 5 10 4
ZINC 1254 1312 1309
BARIUM
Fuel %
Water %
TBN 6.1 7.2 8.3
