Quote:
Engine durability is less than it used to be, but people rarely seem to keep vehicles as long as they used to, so it is apparently not considered a problem.
Wow!
Quote:
Modern (2012) advertising tends to brag about Mileage Estimates of 30 mpg or even 40 mpg. But in extremely fine print, they note that the engine they are describing is 1.2 liters (72 cubic inches) or 1.6 liters (96 cubic inches) or 2.0 liters (120 cubic inches). The giant 350 cid or 427 cid engines sucked down the gasoline, while engines which are 1/6 as big in piston displacement CAN get much higher gas mileage. But there are unspoken details. The impressive numbers of 30 mpg or 40 mpg ARE possible, but only if you drive in a very restrained manner! Those new (tiny) engines ARE able to wind out to impressively high REVS, where they can sound like a Dentist's Drill, where they might create the horsepower claimed, but under those conditions, the gas mileage is far lower. No free lunch!
Wow,Wow!
Quote:
So the LANGUAGE is now rather different than it used to be. A giant V-8 engine running at 1600 rpm made a throaty growl and had impressive available torque for acceleration, even for a 4,000 pound car. A modern 2.0 liter (120 cubic inches) four cylinder engine running at 2,500 rpm makes a lawn-mower sound but also has extra torque for accelerating a 2,200 pound car. Are they the same? Not to me! But the point here is that evaluating big old V-8s and tiny new four-cylinder engines involves two rather different languages, even though the Physics is still the same. With the tiny modern engines, IF you run it at some specific rpm, you CAN get impressive mileage, but no advertising ever mentions that fact.
No new fangled 4 bangers for this guy
