Hi All,
With some of the major brands around here you can buy both 5W-40 and 0W-40 full synthetic oil. The 5W-40 oils tends to cost a little less, and probably more significantly (according to my spec sheets) is only MB 229.3 rated, while the 0W-40 is MB 229.3/229.5
So why do they make both? It looks like the 0W-40 is a better oil, so shouldn't they just drop the 5W-40. Or is there an application or manufacturer spec that calls for 5W-40 for a specific reason.
Here are some figures from the PDS
Castrol Edge 5W-40 (Ti)
API SN, ACEA A3/B4, BMW LL-01, MB 229.3, Porsche A40
Vis 40C 84
Vis 100C 14.0
VI 173
PP -42 degC
FP 208 degC
(HTHS 3.8 ??)
Castrol Edge 0W-40 (Ti)
API SN, ACEA A3/B4, BMW LL-01, MB 229.3/229.5, Porsche A40, VW 502/505, Ford WSS-M2C937-A
Vis 40C 79
Vis 100C 13.1
VI 168
PP -60
FP 211
(HTHS 3.6 ??)
Valvoline SynPower 5W-40
API SN, ACEA A3/B4, BMW LL-01, MB 229.3, VW 502/505, RN 700/710, GM-LL-B-025
Vis 40C 81
Vis 100C 13.6
VI 173
PP -42
FP 236
Valvoline SynPower 0W-40
API SN, ACEA A3/B4, BMW LL-01, MB 229.3/229.5, Porsche A40, VW 502/505, RN 0700/0710
Vis 40C 73
Vis 100C 13.3
VI 183
PP -45
FP 242
The HTHS figures weren't from the PDS, I found them in another thread and they look reasonable.
Thanks.
Vis 40C 84
Vis 100C 14.0
VI 173
PP -42 degC
FP 208 degC
(HTHS 3.8 ??)
Vis 40C 79
Vis 100C 13.1
VI 168
PP -60
FP 211
(HTHS 3.6 ??)
Vis 40C 81
Vis 100C 13.6
VI 173
PP -42
FP 236
Vis 40C 73
Vis 100C 13.3
VI 183
PP -45
FP 242
Thanks.
