I have a 2009 Tacoma with 4L V6. I just changed oil recently at 40,714 miles. The old oil had 3810 miles on it (10 months). The old oil was Castrol GTX 5W-30 high mileage semi-synthetic. I have my oil analyzed by the local CAT lab at every oil change. This batch came back fine, except for a caution on 4 ppm aluminum. None of the previous reports ever had more than 1 ppm aluminum. Is the 4 ppm aluminum anything to be concerned about? It is an aluminum engine. What about bearings? Is there aluminum in the bearing material? Do modern bearings use something other than babbitt metal? Note that the dealer has always changed my oil, until recently, and I do not know what the local dealer uses in that engine, other than 5W-30.
