Did you supply them a baseline sample for the oil you are using?
I noticed that your Boron is also depleted. I believe the oil analysis company I have been sending samples to flags an element if it is under 50% of new.
Your Boron is at 9.9%, according to my baseline it should be at 224 for new oil.
Your Calcium is almost 2X what my new oil baseline was for PP 5W-30, seems like a fair difference, & possible residual from last oil change if a different brand of oil.
Your Magnesium is also depleted at 10%, according to my baseline it should be around 630 for new oil.
They also didn't supply a kinemtic viscosity @ 40 degrees C.
these 3 elements are all part of the lubrication additive package, & I would be replacing oil before the additive package is depleted.
I guess this sample is from 2015, possibly was a different formulation. The new PP 5W-30 is a Dexos 1 Gen 2 oil.
