Hi,
Recently my engine oil has been disappearing on me. I have a 4 stroke, liquid cooled, originally 125cc, bored up to 150cc, done some work on the cylinder head, put in a performance camshaft etc, stock exhaust by the way. When I change my oil after 1000km, it seems like my oil has somehow disappeared. I know it's not a broken piston ring or leaking valves because there is no sign of oil burning that I know of. There is no white smoke coming out of my muffler, the cooling system seems to be fine and the engine operates in the right temperature, because my "your coolant is turning into steam" alarm has not blinked yet.
So what can be the problem. The oil capacity is about 800ml. It drops about 200ml after every 1000km. There is no white smoke. None whatsoever. Do I need to use better oil, any suggestions would be great.
Thank you
Thank you
