Originally Posted By: Joel_MD
Originally Posted By: stephen9666
Originally Posted By: artbuc
Originally Posted By: The Critic
Just pull out the axle and reboot it with a new boot from the dealer.
Too late for that.
It's not necessarily "too late." If they haven't been broken too long I would just clean them out, regrease and reboot.
Your other options are questionable aftermarket axles or not-cheap quality axles.
I agree with this. Last winter I rebooted the outer CV joints on my Saab, after watching a YouTube video to see how they come apart. I spent about 45 minutes on each side, taking the joint off, disassembling, cleaning, greasing, and reassembling. I used Moog boot kits and Red Line synthetic CV joint grease. Also, OTC makes a special pliers that makes it easy to crimp the clamps.
I've had two different friends install the cheap remanufactured axles that RockAuto sells, and both had problems with them. Apparently they use inferior CV joints to save money.
It is not my car and owner can not afford enough down time for me to do what is proposed. Even if I got everything meticulously clean and properly reassembled, I have no guarantee the joints will last because of damage which may have already occurred. She is a widow who totes her grandkids around in this car and she does not want to worry about things going wrong. I can get Subaru remanufactured axles for $170 each which is a lot better than $400 each for new OEM and hopefully better quality than the ultra cheap aftermarket junk. Labot to install both is $250. From what I have read on several Subie forums, Subie axles are problematic at best and I do not want the responsibility for this job. If it were my car, I would jack her up, take my time and fix it myself. I have pulled half axles before but never on a Subie, don't have all the right tools handy and just don't want the hassle of something going wrong. If it were just one axle and I were 20 years younger, maybe I would go for it, but not two axles at almost 67.
