- Joined
- Sep 26, 2010
- Messages
- 9,807
I plan to use an Amsoil BMK28 Bypass Kit (not the full kit as I get the hoses for free as well as the fittings, hose mounts, etc.) on my PSD. Total cost is about $115.00 (filter mount, sandwich adapter, brackets, and o-rings) without the filters. We need not get into the typical discussions about cost, ROI, and the like—for the purposes of this post, these are irrelevant topics.
A few questions:
1. I assume that for the full flow filter, I can continue to use the standard filter for a PSD (provided it fits the mount), correct? I will be using the Amsoil EA BP-90 for the bypass filter.
2. A general question—if hose length was not an issue and provided adequate routing existed, where would you consider the optimum mounting location for the filters to be (e.g. safest place)? The frame rail is structurally sound, but it tends to leave the filters exposed for road debris, etc.
3. I would like to install an electric Autometer oil pressure gauge off one of the blocked inlet/outlets. I am assuming this would work as an acceptable tap location?
Thanks in advance for your thoughts.
A few questions:
