Hello,
I just bought a new camry and changed the oil around 800 miles, along with the filter. It uses the cartridge type filter. I am using OEM filter and gaskets.
The filter housing is leaking, even after replaced the filter housing gasket with two new OEM gaskets. I am certain it's the housing, not the drain plug.
The gasket is in the right spot, and I am not picking it off so to gouge the metal housing. It drips very little, I can barely see a drop accumulate - maybe a drop every few minutes. Will it just stop in time? I am at a loss here. Does anyone have experience with this?
