After replacing tons of tailshaft bearings and seals, these days I just replace the entire tailshaft housing. At this point its a good time to change the rear transmission mount as well. It can be done in one hour or so and you will solve many problems at once. On a 700R4 / 4L60E, you will lose about 1/2 pint of fluid. Anyone with a socket set and a torque wrench can do it.
You can find them cheap on eBay and other online stores complete with bearing and seal.
Diff: Low pitch whine / howl
Trailshaft bearing: Higher pitch whine. Sometimes will rumble at lower speeds moreso when cold.
